reds rakstīja:
tādā mašīnā tikai oldskūl rādio!!!
piemēram šiten ir kaut kas atrodams: http://www.retrosoundusa.com/products/category/id/1
kruta. es par shito!
Unit specs:
# LCD Display w/ enhanced viewing angle & daylight compatible
# LCD Display shows MP3/WMA track names
# AM/FM PLL tuner w/ 30 presets
# 60W x 4 (Integrated amplifier)
# 2pr RCA pre amp outputs to add an external amplifier
# on board CD Changer controller output (to control optional 10 Disc changer) will work with any sanyo compatible unit
# Front mounted USB port, plug in any USB flash drive and play MP3 / WMA files directly off the drive
# Patent Pending INFINIMOUNT adjustable shaft system w/ removable Universal bracket (included)
# Insulated bracket system and external shaft system reduces electrical noise inherent in older vehicles
# Front Aux input, plug in any MP3 player or other portable device, (cell phone, etc)
# Full Function 18 key remote control Note, you don't need the optional cable unless you're remote mounting it
# Main unit is remote mountable and comes with a metal U bracket for mounting under the seat or a glove box
# OPTIONAL external IR sensor w/ 94" cable, allows for easy remote operation via the included remote control
# Adjustable faceplate angle, allows mounting of faceplate display to virtually any dash
# Small 3.54" w X 6.57" d X 1.57" h installation size.
