Trax
Pievienojies: 17 Aug 2006
Komentāri: 7415
Atrašanās vieta: LV
es te fiksi par to W - mums visiem tomeer kaarbas vienaadas. es to pogu labaak neaiztieku - asr visu izdara un nechakareejas. ar to w - kaarba taada kaa ar zjeleju pilna, un par peekshnjaam gaazes pedaalja darbiibaam var aizmirst. es to W neizmantoju (tik cik paarbaudiiju paaris reizes).
Wed Jan 07, 2009 4:03 pm |
Es arī Vēl gan nav mēģināts, bet varbut BAIGOS mēslos iebraucot, tas palīdz akurāti izkārpīties...
Wed Jan 07, 2009 4:09 pm |
NIKSONS
Pievienojies: 10 May 2007
Komentāri: 4423
2012 Alfa-Romeo voyager
palaidniex rakstīja:Oga rakstīja:Hvz ko tas VDC tur pietur. Ar atslēgtu VDC tas auto gandrīz nevienā līkumā nebrauc taisni - visur šķērsām Kas vedina uz domu, ka kaut kāds torseniņš tur tomēr dzīvo.
teicās jau ka jamam ir 3, nevis 2 bloķi pa vidu Torsten C priekšā kādstur un pakaļā kādstur...
Citāts:
The 159 is available in both front and four-wheel drive, configurations. The "Q4" four-wheel drive system utilises a Torsen type C twin differential (front and center differential in the same unit) and is available on the 3.2 litre petrol and 2.4 litre diesel engines.
The gearbox is a six-speed manual on most models (1.8 has a five-speed), and a six-speed automatic Q-Tronic gearbox (Aisin AW TF-80SC) is available for the 1.9 diesel, 2.4 diesel and 3.2 petrol models.
Citāts:
The latest Torsen T-3 (Type C) is a planetary type differential, in that the intended torque split is not 50:50. The Type C is available as single or twin version; the Torsen twin C differential has front and center differential in the same unit.[2]
The Torsen T-3 will be employed as the centre differential in all future non-Haldex Traction Audi models with quattro four-wheel drive, current applications: 2008 Audi S4 (B7), Audi RS4 (B7), and Audi Q7.
Alfa Romeo uses Torsen C twin differential in Alfa Romeo 156 Crosswagon Q4 and then in 159, Brera and Spider Q4 models. Also Toyota uses a Torsen T-3 in the center differential of the Toyota 4Runner and Lexus GX470, with manual locking feature, and GM has a Torsen T-3 centre differential in the (non rear drive) Chevrolet TrailBlazer SS.
Wed Jan 07, 2009 8:40 pm |
NIKSONS
Komentāri: 4423
torsens
video
[/url]
Wed Jan 07, 2009 10:25 pm |
NIKSONS rakstīja:(front and center differential in the same unit)
Khmm - divi diferi vienā unitā... Tas nozīmē ka tas ir saprotams kā viens mezgls bet divi diferi????
Thu Jan 08, 2009 9:59 am |
NIKSONS
Komentāri: 4423
palaidniex rakstīja:NIKSONS rakstīja:(front and center differential in the same unit)
ĪZZĪII
TAS var būt pat vienā korpusā ar ātrumkārbu.
LR pakaļējais un centrālais difs ir vienā korpusā
Thu Jan 08, 2009 10:53 am |
Ja iisi un kodoliigi: Q4 patreizeejos apstaklos ir pilniigs - mashiina iet neticami stabili un prognozejami! Taa ir mana pirmaa pilnpiedzinjas mashina un es neko citu vairs negribu =)))
P.S. Pagaidam videeji 19.5l/100 faktiskais un 17.5 - 22.00 pec kompja (atkariibaa no braukshanas stila). Pa shtrasi rada ~13
Fri Jan 09, 2009 2:07 am |
Hindo
Komentāri: 2000
Atrašanās vieta: Rīga/Ķekava
TheCAT rakstīja:P.S. Pagaidam videeji 19.5l/100 faktiskais un 17.5 - 22.00 pec kompja (atkariibaa no braukshanas stila). Pa shtrasi rada ~13
Tas 3.2 JTS ir tik izsalcis?!
Vai tik nebūtu bijis labāk, ja šamie būtu atstājuši veco labo 3.2 V6 no GTA modeļiem?
Fri Jan 09, 2009 10:46 am |
lāča_kungs
Pievienojies: 04 Sep 2007
Komentāri: 2329
Hindo rakstīja:TheCAT rakstīja:P.S. Pagaidam videeji 19.5l/100 faktiskais un 17.5 - 22.00 pec kompja (atkariibaa no braukshanas stila). Pa shtrasi rada ~13
jā, apetīte ir baigā bet jārēķinās, ka kvatrām tā ir un gan jau "piestums kuņģīti", apradīs un nomierināsies
labots : mans svainis nedaudz kapeik pārdeva benzīnturbopasātu, paņēma oooo A6 lielo turbodīzeli (180zs) + automāts + quattro = bija nedaudz pārsteigts, ka nedzīvo pasakā, jo audī apetīte ir krietni virs 10 litriem. Bet neko, toties tagad brauc un priecājās, bauda dzīvi, sniegu, dubļus
Fri Jan 09, 2009 10:51 am |
Q4 vakar vakarā Krimulda - Ragana - Rīga 110-130kmh pa pilnībā aizputinātu ceļu. Viss pofig.
Par patēriņu - 3.2 + automāts + AWD + tas, ka dzinējs nav vēl iebraukts. Ko jūs gribējāt? 8L/100km pilsētā?
Fri Jan 09, 2009 12:10 pm |
NIKSONS
Komentāri: 4423
Oga rakstīja:Q4 vakar vakarā Krimulda - Ragana - Rīga 110-130kmh pa pilnībā aizputinātu ceļu. Viss pofig.
07/01 no agri rīta ar LR braucu uz Gulbeni. Tas bija pats "melnākais" rīts šoziem - putenis pilnā sparā, pirmo šķuri redzēju Gulbenes rajonā.
Nezinu, ko domāja tie kas uz 60-70 čunčināja pa labo joslu, brīdī kad es ar ~ 110 gāju garām pa aizputināto joslu. Droši vien, ka pie stūres pilnīgs . Nevaru teikt, ka viss pilnīgi fofig - tomēr viegli nēsāja un bremzēšanas ceļš lika , bet ne turp ne atpakaļ neviens pat nemēģināja braukt ar man tuvu ātrumu.
Vidējais patēriņš pēdējos 15.000 km [saskaņā ar BD] 8,6 L/100 km
Sorry par Tas tikai lai paķircinātos
Fri Jan 09, 2009 12:22 pm |
Vakar arī čaļi ar SUViem un lendkrūzeriem tā prātīgi, pa cik necik tīru 1. joslu... Baltais laikam bija ātrākais transportlīdzeklis Vidzemes reģionā
Fri Jan 09, 2009 1:07 pm |
Hindo
Komentāri: 2000
Oga rakstīja:Par patēriņu - 3.2 + automāts + AWD + tas, ka dzinējs nav vēl iebraukts. Ko jūs gribējāt? 8L/100km pilsētā?
8L/100 km negaidīju, bet 19,5 es ar nebiju gaidījis.
Fri Jan 09, 2009 1:12 pm |
Es nemaz nezinu, cik viņš vidēji apēd Pilsētā kompis praktiski visu laiku rāda >20L/100km
Labākais risinājums ir... neslēgt iekšā borta datora degvielas patēriņa rādījumu priekšējā panelī
Fri Jan 09, 2009 1:15 pm |
Fri Jan 09, 2009 1:21 pm |
