Kak pochistit esho ne nashol, no tut opisanjije iza chego onji tak delajut...
Citāts:
The underlying problem is that Alfa used the wrong grease when they built the wiper motor. It migrates from the worm drive gear onto the sensor disc that detects when the wipers are at their parked position. So every time the wipers try to park (like they do every wipe on intermittent), the copper strips don't make a good contact and the wipers judder.
Putting the wipers on fast full will sweep a bit of the grease out of the way, and so will cure the problem for a week or two.
Taking the wiper motor off and clearing out the excess grease will solve it for a year or two.
The real answer is to remove all the grease from the motor and to repack it with the modified grease from Alfa, which will cure the problem permanently.
Citāts:
Nu tam probljema v tom chto metaljicheskij disk (s potencometrom?) zasirajetsa s maslom ot mehanizma i propodaet kontakt. Vot i etot disk nado pochistit. Ja sam mehanizm zadnjego dvornjika chistil, tam nechego slozhnogo nebilo. Potom zarabotalo idealjno
ну задний работает хорошо!!меня больше переднии волнуют!
