pardodu gultnu komplektu prieks M32 karbai (159. AR 1,9Jtd):
1 x 28mm Rear End Case Bearing
2 x 25mm Rear End Case Bearings
2 x Upper and Lower Mainshaft Front Case Bearings
1 x 25mm Input Bearing
1 x 27mm Input Bearing
2 x Driveshaft Oil Seals
2 x Input Shaft Seals to suit the different Input Shaft Size
1 x O Ring Differential Bearing Flange Seal
cena 300 EUR
GTV6
