Atbildēt pie šī temata 2 lapa no 9 lapām pavisam
Iet uz lapu Iepriekšējais  1, 2, 3, 4, 5, 6, 7, 8, 9  Nākošais
Stelvio
Izskatas labs tas stelvio. Strategija prezentet top versiju, kas ciparos izgriez pogas konkurentiem pec sajutam ari liekas laba. Liek potencialam premium pircejam padomat. Good good Smile
Mana 166 ir melna!
Starpcitu, pamanijat, ka tas chals kas prezenteja bija nochiepis dalju no uzrunas no Palaidnieka runas Autobrava Wink 1:1
xls99 rakstīja:
Aha - tieši nodomāju, kurš viņam rakstījis runu ;D
If it ain't broke, try harder
Citāts:
The Q4 system's architecture includes an active transfer case and front differential designed to meet the specific technical requirements of Alfa Romeo, entailing the rapid-response management of high torque levels, with a compact, lightweight set-up. The transfer case makes use of advanced active clutch technology to deliver an outstandingly dynamic ride combined with good fuel economy.
In normal conditions, the Stelvio Quadrifoglio with Q4 system acts like a rear-drive vehicle, with 100% of the torque sent to the rear axle. As the wheels approach their grip limit, the system transfers up to 50% of the torque to the front axle via a dedicated transfer case. To modulate torque distribution with the utmost speed, the system uses a high degree of mechanical over-slip (up to 2.5%) between the two axles, which translates into class-leading control in terms of traction and directional stability when cornering.
Combined with Q4 all-wheel drive for the first time, Alfa Romeo's Torque Vectoring technology optimises the Stelvio Quadrifoglio's drive distribution and accentuates its sporting character. The two clutches in the rear differential make it possible to control torque delivery to each wheel separately. So power is transferred to the ground more effectively, even when you drive the car to its dynamic limits. This makes the Stelvio safe and fun to drive at all times, without recourse to intrusive inputs from the stability control system.
Neko nesapratu, pakaltilta divsajugu difts, tatad blokis, razdataka ir "aktivais sajugs", kas tas tads? Prieksejais laikam ir parastais valejais difs. Dodot rucka vismaz tris riteni griezisies, kas salidzinot ar parketnieku parasto ir riktigi kruta Wink
http://www.alfaromeopress.com/press/article/world-preview-alfa-romeo-stelvio
Mazlietoti itāļu auto no Vācijas, Beļģijas, Francijas, Itālijas... autofficina.lv
Fantastiski smuka mašīna!!! Visādi Macani/Cayenni, Jaguari/Bentley un Bmw X/Audi Q vienkarši atpūšas!!!
 applausi  bravo,bravo!!!
Alfa Romeo, Maserati, Abarth, Jeep, Fiat serviss un rezerves daļas... autofficina.lv
yo  love  ihaaaaa
Pat ņemot vēra to, ka man SUVi ka tādi īpaši neuzrunā!
Pirmaja momenta ta ka nepamaniju, bet kad ieskatas labak Stelvio loooti atgadina Maserati Levante. Virsbuves aprises ir vienadas.
Atskiriba ir detaljas, durvju, sparnu ieliekumi savadaki, kapots savadaks, reste, buferi savadaki, lampas savadaki. Kopuma Alfa skaistaka.
Maserati savu bobiku var dzit muzeja un aizmirst ka neizdevusos projektu.
https://www.youtube.com/watch?v=HnpvDYfs5XE
https://www.youtube.com/watch?v=tro6HZS3rkY
Liekas, ka alfisti visā pasaulē mainīs orientāciju un no pilnīgiem SUV noliedzējiem , kļūs par to mīļotājiem SmileSmileSmile
maz ticams,jo neaizmirsti ka tā ir alfa Smile konkrētais ir lidziigs,da i kā visi citi,ir jābūt lielai motivacijai lai paņemtu alfu Very Happy
labums ir tāds,ka pēc 5ci gadi maksās taas alfas tieši neko,un varēs pirkt pa kapeikām Very Happy es no juļačkas neaiteiktos Very Happy
Pilnīgi tev piekrītu!!!
Tāpat, kā kādreiz nemīlēja Vettel'u Laughing
Par ko Vettelu milet? hmm  offtopic
tad to lamatu ir šausmīgi jāsēdina aiwa
